Fixed thread title.
From reading that article, its pretty clear the author has no real knowledge about fuels...
that and the fuel burn quote that was mentioned above.The consequences of using EPULP in an unsuitable car are the same as using E10: it will ruin the fuel delivery system.
Yet another case of bad journalism.
For anyones information - using premuim fuel for 2 stroke engines is highly recommended. Everything special that the engine needs is in the 2 stroke oil, and the better the fuel you put in, the better the engine will run.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
